Old 04-19-2012, 06:28 AM
Avatar mimicking after
Hi all,
I'm trying to make an avatar mimic the head movements of a participant with a delay of 4 seconds. In the code below, I'm writing the euler information of the viz.MainView to a file (1.log) and after 4 seconds, I'm trying to read from the beginning of that same file (thus creating a delay of 4 seconds). But after 4 seconds, I get an error message (IOError: [Errno 0] Error) and I think that's because I'm reading from the same file I'm writing to. I understand this could be problematic, but I don't know an other approach for my problem. Any help is greatly appreciated!
Regards,
Frank
import viztask
import time
#CONSTANTS
PATH = '.\\'
PARTICIPANT = 1
TRACKING_DATA = open(PATH+str(PARTICIPANT)+".log", 'w+')
TIMER_SPEED = 0.1
SEC_DELAY = 4
def logTrackingData():
    orientation = viz.MainView.getEuler()
    data = str(orientation[0])+' '+str(orientation[1])+' '+str(orientation[2])+'\n'
    TRACKING_DATA.write(data)
def readTrackingData():
    rotation = TRACKING_DATA.readline()
    print rotation
def readWithDelay():
    #Wait 4 seconds
    yield viztask.waitTime(SEC_DELAY)
    vizact.ontimer(TIMER_SPEED, readTrackingData)
vizact.ontimer(TIMER_SPEED, logTrackingData)
viztask.schedule(readWithDelay())
Old 04-19-2012, 08:03 PM
Would it work for you to save the data in a list and read it from there?
Old 04-20-2012, 02:32 AM
Works like a charm, thanks Jeff! My solution consists of using three lists (one for yaw, pitch, and roll) which I append the current yaw, pitch, and roll to and start reading from the beginning after waiting 4 seconds. My only 'concern' now is that each list is growing with 10 floats/second, so they will get pretty big after a few minutes (my experiment will last around 10 to 15 minutes of mimicking I guess). Of course I could delete the information from the list after it has been read, but will the size of the lists pose any problem at all?
Old 04-20-2012, 07:17 AM
For anyone with the same problem, here's my solution I eventually used:
import viztask
#CONSTANTS
TIMER_SPEED = 0.1
SEC_DELAY = 4
yaw_list = []
pitch_list = []
roll_list = []
	yaw_list.append(orientation[0])
	pitch_list.append(orientation[1])
	roll_list.append(orientation[2])
	global yaw, pitch, roll
	#Read information
	yaw = yaw_list[0]
	pitch = pitch_list[0]
	roll = roll_list[0]
	#Delete information already read
	yaw_list.pop(0)
	pitch_list.pop(0)
	roll_list.pop(0)
	#Wait 4 seconds
Avatar & Motion Capture Interface Angie Vizard 1 08-05-2010 07:17 PM
avatar scale and link.setpos conflict? sircedric4 Vizard 0 09-29-2009 08:48 AM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 10:44 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
