Old 04-18-2012, 01:31 AM
Joran Joran is offline
Send a message via Yahoo to Joran
Lightbulb Touch functionality
I have been working with the touch functionality and have played with viztouch. I haven't installed the latest version of Vizard yet, so I am at risk this has already been solved, but I will go for it anyway.
If you use Vizard on Windows 7 with a touch screen there is mouse emulation. The problem with mouse emulation is that when you touch the screen, no mouse down is generated. It will try to distinguish between a left click, right click or drag. In the current version of viztouch (that I use) it leaves the mouse emulation on. That means that for the first touch it uses the mouse emulation and for the dual and multi touches you will get the raw touchpoints.
It is possible to turn the mouse emulation of by using RegisterTouchWindow(hWnd, TWF_WANTPALM). If you do this, even the normal mouse_up, mouse_down and mouse_move events are enough for a single touch screen. So I would like the option to turn off the mouse emulation in viztouch. And maybe an extra mode, like MODE_SINGLETOUCH that just disables the mouse emulation.
Old 04-18-2012, 02:40 AM
Hmm... Did some more experimenting. But only doing the RegisterTouchWindow with TMF_WANTPALM, does not let the mouse_down work as I thought. It will not directly generate a mouse down when the screen is touched. But it still should immediatly generate a touch down.
Old 04-24-2012, 05:09 PM
The TMF_WANTPALM flag seems to just disable filtering of palm touches, resulting in slightly lower delays for touch events. I can add an option for using this flag, but I'm still not sure how to disable mouse emulation.
Old 04-25-2012, 01:07 AM
You are right. It does not disable the mouse emulation. But it is less obtrusive when you use the flag. My current project is not usable if the flag is not set, because I will miss too many touch points. So I would really like support for the TMF_WANTPALM flag.
Old 04-25-2012, 08:51 AM
The value of the TWF_WANTPALM flag is 2. So for now you can modify viztouch.py by changing line 268 to:
ctypes.windll.user32.RegisterTouchWindow(e.hWnd,2)
There is also a TWF_FINETOUCH flag. I'm not sure how useful it is, but I'll probably add support for that as well.
Feedback on debugger functionality dcnieho Vizard 0 05-20-2011 10:36 PM
assigning the mouse functionality to Keyboard events jaffaaswami Vizard 2 10-07-2010 10:58 PM
assigning the mouse functionality to Keyboard events jaffaaswami Vizard 0 10-06-2010 06:49 AM
Mimicing Haptic Touch Events njstaley Vizard 1 06-29-2010 02:58 PM
Adding USB functionality to Vizard rubberpimple Plug-in development 2 01-25-2008 02:59 PM
