Old 03-30-2012, 10:00 AM
Veronika Veronika is offline
create group of objects
hello,
how I can create one group of objects?
Because I want to set collision, but for each object separately - it will be very time-consuming.
thanks
Veronika
Old 03-30-2012, 10:12 AM
Each object will need it's own collision shape. Are all these objects you want to group together the same type of object? Can you describe your application?
Old 03-31-2012, 12:13 PM
viz.phys.enable()
ground.collidePlane()
<node3d>.collideBox()
<node3d>.disable(viz.DYNAMICS)
avatar.collideBox()
avatar.disable(viz.STATICS)
avatar.enable(viz.COLLIDE_NOTIFY)
I have approximately 30 objects - each object is '*.wrl'. And I need to set collision between avatar and objects and therefore I need to create group of objects.
Old 04-02-2012, 09:32 AM
You'll need to add a separate collision shape for each object.
Old 04-03-2012, 12:45 AM
ouuu, yes?
you didn't give me a good information
but thanks
artoolkit load 3d objects into application xcuddlex Vizard 8 04-18-2011 03:00 AM
Trouble picking text3d objects Salvar Vizard 4 12-01-2010 04:07 PM
static or dynamic objects shahramy Vizard 2 11-10-2010 01:32 AM
Semi-circle array containing target and distractor objects ptjt255 Vizard 3 08-04-2009 04:09 AM
