Old 03-29-2012, 09:58 PM
nabrahamson nabrahamson is offline
Vizproximity questions.
We have been using the physics engine to determine if two objects are touching in static models. Unfortunately a model that we are trying to test for touching objects contains 1.14 million primitives, and our application crashes without any errors/exceptions reported.
Would the vizproximity library be more efficient than using the physics engine?
Old 03-30-2012, 12:42 PM
The vizproximity module uses simple bounding spheres/boxes to detect proximity. If you need fine-grained polygon based collision testing, then the vizproximity module will not be useful in this case. One option would be to create a low-poly version of your objects and use them for the collision tests.
Old 04-03-2012, 08:10 AM
So is there good way to capture the state of the application when it crashes without any debug information?
Old 04-04-2012, 05:59 PM
Not currently. If you monitor the memory usage of the process in task manager, is it nearing a 2GB limit before crashing?
physics, vizproximity
VRay, and Complete Character animation questions Lithium Vizard 1 07-27-2011 01:21 PM
Two questions (networking) TrashcanPatrol Vizard 5 05-07-2009 02:46 PM
3 Easy Questions JMOwens Vizard 3 10-03-2007 01:10 PM
General Questions about Vizard: World Viz dav Vizard 5 08-28-2006 04:44 PM
Antialiasing questions oodini Vizard 1 12-06-2005 01:08 PM
