Old 11-16-2011, 03:50 AM
robgulwell robgulwell is offline
Question how do I remove the “flying Robot”
Hi can any one help, when controlling an avatar with the mouse and button commands, how do I remove the “flying Robot” from the non camera view?
Old 11-16-2011, 04:28 PM
Are you creating multiple windows with different views? If so, you can prevent a node from rendering to all windows using the <node3d>.renderOnlyToWindows command.
Old 11-21-2011, 12:37 AM
Jeff many thanks will give it a go today and let you know the outcome.
Old 11-21-2011, 07:44 AM
Jeff tried and failed
Old 11-21-2011, 05:46 PM
Sorry, that's a Vizard 4 command. The following should work for Vizard 3:
import steve
steve = steve.Steve(pos=[0,1,7],euler=[180,0,0])
court = viz.addChild('court.ive')
subWindow = viz.addWindow()
mask = viz.addNodeMask()
steve.setMask(mask)
viz.MainWindow.setCullMask(mask)
camera view remove flying robot robgulwell Vizard 0 11-15-2011 01:01 AM
vizdlg Panel: Add and remove disbeat Vizard 2 02-08-2011 12:44 PM
Remove link and have object drop/collide? cgibb Vizard 6 03-02-2010 04:18 PM
How to remove the head from avatar Xianshi Xie Vizard 2 06-22-2009 09:05 AM
How to remove a modifier Joran Vizard 1 05-27-2009 12:53 PM
