Old 10-17-2011, 04:45 AM
chris_user chris_user is offline
CyberGlove
hope anybody can give me some tips to integrate a CyberGlove.
Is it possible to set it up to run on the tracking computer? All code references I've found till now show the CyberGlove assigned to the rendering machine.
Thanks in advance,
Chris
Old 10-18-2011, 12:26 PM
Vizard needs to be running on the same machine as the DCU. However, you maybe be able to have two device managers communicating across the machines so that the glove does not need to be connected to the rendering machine. Too see if that's possible check in with CyberGlove Sytems support.
Cyberglove left hand not able to connect llqqff Vizard 2 07-21-2010 12:47 PM
Connecting cyberglove with character llqqff Vizard 1 04-26-2010 12:30 PM
Immersion Cyberglove connection problem gwfassociates Vizard 1 05-17-2009 04:29 PM
Cyberglove on Apple Steve_HT Plug-in development 1 04-30-2008 08:40 PM
data glove bug (5DT glove, Cyberglove, etc) discovered in R3 beta4 release mspusch Vizard 1 02-01-2007 08:41 PM
