Old 08-15-2005, 04:11 PM
dominic dominic is offline
input & gamepad
Hey,
I have the following code. So, if I add one of those viz.input calls to get input then I am not able to get any input from the gamepad anymore. If I remove the viz.input line, then everything works just fine.
What am I doing wrong?
thanks,
dominic
PS: How can I submit code so that it keeps the indentions?
#testing
import sid
def userInput(num):
print 'num: ', num
if viz.running():#tried it with or without this magic line
h = viz.input("please enter a number: ")#PROBLEM
sid.callback(sid.BUTTONDOWN_EVENT, userInput)
Old 08-15-2005, 05:01 PM
Try placing the import sid statement after you call viz.go(). Also, when posting code place it between [code ] tags. Example:
[code ] some code [/code]
