Old 08-12-2005, 04:07 PM
dominic dominic is offline
gamepad
I want to use input from a gamepad, so in my main class I have:
#main class
from Joystick import *
import sid
oh = Joystick()
sid.callback(sid.BUTTONDOWN_EVENT,oh.sayhello)
and in my Joystick.py file / class, I have:
class Joystick(object):
def sayhello(self, num):
print "hello world ", num
So, everything works but the line "oh = Joystick()" is highlighted in yellow. Any ideas, how I can fix that or what I am doing wrong?
Dominic
Old 08-15-2005, 10:14 AM
I tried out your sample code and I didn't get any highlighted lines. This ususally happens when you are editing/changing a module. It is more of a python issue. I believe reloading the module fixes this. To reload your module you would type the following in the interactive window:
reload(Joystick)
Also, restarting Vizard should get rid of it.
