Old 09-08-2011, 01:04 AM
sleiN13 sleiN13 is offline
Bump mapping
I know it was possible in Vizard 3.0 but I can't find any documentation about it in Vizard 4. Also using the Vizard 3.0 command in Vizard 4.0 doesn't seem to do anything or I'm just doing it wrong
Old 09-15-2011, 10:33 AM
Are you referring to the <node3d>.bumpmap command? It's not documented, but it should still be available in Vizard 4.0.
Old 09-16-2011, 01:24 AM
Yes that's the one.
I apply it to a Quad and than apply the texture to it but there seems to be no effect. If i switch the order around (so first the texture and then the bumpmap command) the bumpmap image is used as texture on the plane or so it seems.
What are the requirements for the bumpmap image file? Now it's a single layer gray scale image.
Old 09-27-2011, 12:16 PM
The command uses a normal map. Normal maps usually are a bluish color. It sounds like you have a height map.
3D Texture Mapping - gluBuild3DMipmaps not supported stefs Vizard 1 04-23-2008 12:00 PM
3D Texture Mapping in Vizard? stefs Vizard 2 03-25-2008 04:34 AM
mapping method FlyingFish Vizard 1 07-12-2007 10:06 AM
bump mapping cade_mccall Vizard 8 02-03-2006 03:48 PM
Bump mapping? FlyingWren Vizard 1 04-07-2003 12:07 PM
