Old 08-08-2011, 02:37 AM
Veronika Veronika is offline
linking Patriot and 5DT glove
Hello, I want to link polhemus patriot and 5DT glove. Can you help me? I dont know, which order I need use.
Old 08-08-2011, 12:37 PM
The following should show a hand that's animated with glove data and moves with the Patriot sensor. Does this work for you?
import hand
#Identify the data glove's port.
PORT_5DT_USB = 0
#Add the 5DT sensor
sensor = viz.add('5dt.dls')
#Create a hand object from the data glove
glove = hand.add(sensor,hand.GLOVE_5DT)
#Connect to Patriot sensor
polhemus = viz.add('polhemus.dle')
patriot = polhemus.addPatriot()
#Link the hand to the Patriot data
viz.link(patriot,glove)
Old 08-09-2011, 02:49 AM
yes, I have this code:
import hand
viz.MainView.translate(0,0.02,-0.4)
viz.clearcolor(viz.GRAY)
PORT_5DT_USB = 0
sensor = viz.add ('5dt.dls')
viz.link(glove,patriot)
but if I press F5 for starting, vizard write:
** ERROR: Failed to load plug-in: 'polhemus.dle'
File "Vizard2.py", line 14, in ?
AttributeError: 'VizExtension' object has no attribute 'addPatriot'
** Load Time: 0.48 seconds
and I don't know, what is a problem. But if I play another application, all is OK.
yes, this work is for me.
Old 08-09-2011, 02:55 AM
and if I change last link (patriot and glove)
it's same problem
Old 08-09-2011, 01:11 PM
Do you get an error when you run the following:
Old 08-09-2011, 10:51 PM
yes, I have error:
could you help me with this problem?
Old 08-10-2011, 02:25 PM
Try re-installing Vizard and let us know if that helps.
Old 08-15-2011, 05:36 AM
OK, I will try to install Wizard - trial version in my notebook. because on our university I don't know passport for re-installing. thank
Old 08-15-2011, 12:46 PM
If Vizard is already licensed, you won't need to enter a serial number when re-installing. Our downloads page has a link to the latest Vizard installers.
