Old 07-18-2011, 02:01 PM
nicmurr nicmurr is offline
PanoramicHelp
Hello!
I am new to the worldviz and I am just learning Python. I work in a biomechanics lab and we are re-creating virtual environments for work with rehabilitation techniques.
I am attempting to re-create a lab setting using standard .jpg pictures that I have taken of the lab. I completed the tutorial, however when I substitute the picture call in the script it continues to show the tutorial model.
My main question is:
1) How can I route the script to the pictures that I choose instead of the worldviz tutorial model?
Old 07-18-2011, 06:01 PM
Which tutorial did you use for this? Can you post some example code?
Old 07-19-2011, 10:04 AM
Panorama Help
Hello Jeff,
I used the following code
env = viz.add(viz.ENVIRONMENT_MAP,'lab_L.jpg')
sky = viz.add('skydome.dlc')
sky.texture(env)
I essentially substituted the 'townhall_L.jpg' for lab_L.jpg'
The lab .jpg files were copied to the directory that the townhall jpgs are contained with the exact same file parameters, eg lab_negx etc
The tutorial used was Tutorial: 360 Panoramas
Old 07-20-2011, 02:09 PM
Can you attach the script and images you are using or upload here so I can take a look?
