Old 06-20-2011, 12:58 AM
chris_user chris_user is offline
get tracker position and euler
hello,
hope somebody knows a more simple solution to get the coordinates of the tracker and the orientation from the intersense.
my actual solution is to load the vizsetupcfg.py and use getPosition and getEuler form headpos and headori; to get that working I needed to modyfy the vizsetupcfg.py and set the first five lines of the createCustomComposite as a global. actually it is working but i'm quiet shure there must be a more elegant solution to this task. tips and hints are welcome.
thanks,
chris
Old 06-24-2011, 11:29 AM
Does the following work for you?
import viztracker
viztracker.go()
tracker = viztracker.get('input0')
def printTrackerData():
	print tracker.getEuler()
	print tracker.getPosition()
vizact.ontimer(0,printTrackerData)
Old 07-01-2011, 02:31 AM
Thanks Jeff!
That's exactly what I needed.
display the position and euler coords of the main view Josh Vizard 1 03-22-2010 11:48 AM
euler problems in Vizard 3.0 v-clizzin Vizard 3 08-16-2007 07:10 PM
