Old 06-08-2011, 03:44 PM
hercyna hercyna is offline
Question Java GUI imported in Vizard 3
Hi all, I'm trying to find a way to import an existing Java GUI to a scene created by Vizard 3.
After googling for a solution to bridge Java and Python, I found JPype, with which I can start a Java Virtual Machine and then call a Java GUI in a Vizard script. The problem is the GUI just shows up independently from the VE scene. Then I'm kind of stuck here... What should I do next? How could I put the GUI into the VE? Any suggestions? Or at least is it workable or not...Thanks!!
java gui
How can i import the code form a Java program to Vizard? alberto_redo Vizard 1 10-07-2010 01:18 PM
vizard and java -> jython? Johannes Vizard 10 06-28-2005 11:23 AM
