Old 05-08-2011, 11:29 AM
suwan116 suwan116 is offline
Import 3DS to Vizard
Im new to Vizard so im a total noob! lol.
Basically i wanted to import a residential property i developed in 3ds max to vizard. I exported the .IVE file, but im not sure how to open it. I downloaded Vizard 3.0 (i hope this was the right one) from there website, but how do i import it?
Please could you help
Old 05-09-2011, 01:28 PM
To load a .ive model you exported use the viz.addChild command in your script:
myModel = viz.addChild('model.ive')
Using the code above the .ive file should be in the same directory as the script to be found.
Also, download the Vizard 4 Beta to use the Inspector tool. That allows you to view Vizard compatible models without running a script.
How can i import the code form a Java program to Vizard? alberto_redo Vizard 1 10-07-2010 12:18 PM
How to import the defaultdict into vizard knightgba Vizard 3 07-26-2010 01:35 PM
