Old 04-09-2011, 05:18 PM
Question Blurryness, see image
Hello friends, my textures get way too blurry when seen on an angle, any ideas as how to minimize this problem?
Ex:
Old 04-09-2011, 07:44 PM
Try using the <texture>.anisotropy or <node>.anisotropy commands. Anisotropic filtering is used to alleviate the exact problem you are having.
If that doesn't help, then you might need to use a higher resolution image.
Jpeg Image issue? VelvetElvis Vizard 0 03-05-2010 06:20 AM
screen image erchrastil Vizard 8 06-27-2008 11:45 AM
View an image on the Fakespace HMD roman_suvorov Vizard 16 05-23-2008 07:51 AM
Only part of tiled image vizmaster Vizard 5 09-11-2006 12:11 PM
