Old 04-08-2011, 06:20 PM
Zhi Zhi is offline
Sychronization between cluster machines
Hi All,
I have a script based on clusters in Vizard 4.0 beta. I simulated an avatar walking action. However, when look through an Sensics xSight HMD, the avatar's action was not synchronized between the two eyes (I can see 4 arms and 4 legs when the avatar walks). The two eye's view were rendered by two computers separately via the vizard cluster. I tried to use the vizcore.cfg file to force the synchronization, i.e.:
viz.cluster.master.sync = 1
viz.cluster.master.sync_gpu = 1
However, it does not change anything.
Can anyone help me? Thanks.
Zhi
Old 04-10-2011, 06:38 AM
Zhi Zhi is offline
Is this a bug in Vizard 4 beta 2 ?????
Old 04-10-2011, 11:14 AM
Zhi Zhi is offline
What's interesting is that, the unsychronization does not occur if I only set the action state to a single one. However, if I use mouse to control the avatar's action (i.e. walk) to different direction (using .move and .spinTo methods), then the unsychronization became noticeable.
Old 04-10-2011, 08:13 PM
Zhi Zhi is offline
It seems a bug in Vizard. If I change the avatar's action status using the .state() method, the unsynchronization will occur between the master and client machines.
Old 04-11-2011, 05:24 PM
Thanks, I was able to reproduce the issue here. Should be fixed in the next Vizard 4 release.
Old 04-11-2011, 06:02 PM
Zhi Zhi is offline
That would be great. Thanks!
Question about cluster replacement mizutani_jun Vizard 1 02-18-2011 02:49 PM
Question about GUI and CLUSTER mizutani_jun Vizard 2 01-02-2011 03:35 PM
Lighting on a 3 channel cluster ajmurray Vizard 3 10-10-2007 09:57 AM
Cluster Help videcuk Vizard 12 09-21-2007 02:14 PM
quad_buffer cluster John P Vizard 4 06-07-2006 10:01 PM
