Old 04-04-2011, 06:43 AM
disbeat disbeat is offline
audio files suported
To document my application I need to write which audio formats are suported by vizard. I couldn't find it anywhere else.
Thank you
Marco Simões
Old 04-13-2011, 02:14 PM
Vizard supports any video or audio file format for which your system has a codec.
Old 04-13-2011, 04:08 PM
i could not get mkv video files to work in vizard even though vlc player plays them ok
Old 04-13-2011, 05:12 PM
I think VLC has embedded codecs. A better test to see if it will work with Vizard is to use Windows Media Player.
Old 04-13-2011, 05:21 PM
Thank you Jeff.
Old 04-14-2011, 03:42 AM
Hi Jeff
its ok i figured it out i was using viz.add(filename) instead of viz.addVideo(filename)
Sorry about that.
How to edit the skin tones of the complete characters' cfg files? vEsotu Vizard 3 09-23-2008 01:07 PM
Which software can be used to edit .cfg (CAL3D) files luakt Vizard 4 09-12-2008 08:18 AM
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 01:21 PM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 04:23 PM
Including Files that Include Other Files vjosh Vizard 1 09-21-2004 05:44 PM
