Old 03-19-2011, 12:20 PM
Jerry Jerry is offline
restart plugin within script?
I am using an Inertiacube which works fine for about 2 minutes, but then
the orientation data begin to lag the motion by approximately 0.5 sec.
If I stop and restart the script the Inertiacube starts out fine again
but then develops the delay.
Is there some way that I can unload and then reload the intersense
plugin while the program is running instead of stopping and restarting
the script?
Or any ideas about how to eliminate the lag once it begins? Sort of
like flushing the buffer.
Old 03-22-2011, 02:02 PM
Make sure you are using the intersense.dle plug-in rather than the deprecated intersense.dls plug-in?
If you are than perhaps the cube is defective. Is the result the same with Intersense's software?
Live Characters plugin Frank Verberne Vizard 7 03-01-2012 02:23 AM
Howto debug a custom plugin? reedev Plug-in development 3 04-23-2009 02:16 PM
Vicon Plugin Micheal Plug-in development 2 08-29-2007 03:03 AM
