Old 03-02-2011, 11:10 AM
Question Mouse Selection Area Question
Is there any way that I can create a selection box with a mouse click (just like selecting icons on the desktop with the mouse) in vizard? Is there any builtin function for doing this? Ideally, the selection are would return the objects that were selected.
Does anyone have any suggestions for doing this?
Thank you.
Old 03-02-2011, 01:24 PM
This is what I managed to do so far:
import viztask
def DrawLineTask():
while True:
viz.startlayer(viz.QUADS)
viz.vertexcolor(viz.RED)
yield viztask.waitMouseDown(viz.MOUSEBUTTON_LEFT)
pos = viz.mouse.getPosition()
viz.vertex(pos[0],pos[1],0) #0
viz.vertex(pos[0],pos[1],0) #1
viz.vertex(pos[0],pos[1],0) #2
viz.vertex(pos[0],pos[1],0) #3
line = viz.endlayer(parent=viz.SCREEN)
VertexLink = vizact.ontimer(.01, copyTransform, viz.Mouse, line.Vertex(0), line.Vertex(1), line.Vertex(2), line.Vertex(3))
yield viztask.waitMouseUp(viz.MOUSEBUTTON_LEFT)
VertexLink.remove()
line.remove()
viztask.schedule( DrawLineTask() )
def copyTransform(mouse, vertex_a, vertex_b, vertex_c, vertex_d):
M = mouse.getMatrix()
A = vertex_a.getMatrix()
A[12] = M[12]
A[13] = M[13]
vertex_c.setMatrix(A)
A[12] = M[12]
vertex_b.setMatrix(A)
A[13] = M[13]
vertex_d.setMatrix(A)
How can I make it now do the selection under the square?
Old 03-03-2011, 05:34 PM
For each object in the scene you could get the 2D screen coordinate corresponding to the object's position using the <window>.worldToScreen command. Then you could see if that 2D position falls between the values of the selection box. If it does, that means it was selected.
This world require your selection box includes the objects center to register as a selection:
import viztask
viz.mouse(viz.OFF)
objects = []
for x in (-1,0,1):
	for y in (1,2,3):
		object = viz.addChild('white_ball.wrl',pos=[x,y,5],cache=viz.CACHE_COPY)
		objects.append(object)
def DrawLineTask():
	while True:
		line.alpha(0.2)
		pos2 = viz.mouse.getPosition()
		findSelected(pos,pos2)
		VertexLink.remove()
		line.remove()
		yield viztask.waitTime(0.5)
		for object in objects:
			object.color(viz.WHITE)
	A[12] = M[12]
	A[13] = M[13]
	A[12] = M[12]
	A[13] = M[13]
def findSelected(pos,pos2):
		x,y,d = viz.MainWindow.worldToScreen(object.getPosition())
		if pos[0] < pos2[0]:
			low_x = pos[0]
			high_x = pos2[0]
			low_x = pos2[0]
			high_x = pos[0]
		if pos[1] < pos2[1]:
			low_y = pos[1]
			high_y = pos2[1]
			low_y = pos2[1]
			high_y = pos[1]
		if x > low_x and x < high_x and y > low_y and y< high_y:
			object.color(viz.RED)
Old 03-04-2011, 02:54 AM
Thank you. It did the trick!
Mouse pointer problem Albert Russel Vizard 2 02-21-2011 01:10 AM
Warning mouse() -> Set mouse() of window johannes2 Vizard 1 08-19-2010 02:11 PM
how to remove velocity when mouse is disabled? jvacare1 Vizard 2 02-18-2010 10:25 AM
Navigating an avatar using mouse position(2D) in 3D environment james007 Vizard 1 10-16-2009 11:29 AM
Setting up a 'reaction area' Karthi Vizard 4 01-29-2004 04:39 PM
