Old 05-16-2005, 09:26 AM
Johannes Johannes is offline
Speech Recognition
1. M. told me vizard has some built in Speech recognition?
How can I find, activate, "talk" to it?
Otherwise I would have to program something myself... http://surguy.net/articles/speechrecognition.xml
MS Speech Developement kit is installed...
2. Because our red-blue glasses do not work with viz.anaglyph, M. told me there is a way to adust colors which might help?!
How? He might have mentioned another way to improve 3d impression with the glasses but I forgot.
Thank you,
Johannes
Old 05-16-2005, 11:46 AM
mspusch mspusch is offline
Hi Johannes, I have to appologize for not being up-to-date with the two features we talked about -
1) it turns out that the old MS-speech recognition plugin which used to be supported in VRUT is not supported any more. So, if you want speech recognition, you will need to add it as a plugin.
2) the feature for adjusting colors for red-blue glasses has not been implemented, so the only anaglyphic mode Vizard supports is the red-blue. What are the artifacts you see when using red-blue glasses? Maybe higher density color filters in the glasses would improve performance?
m.
