Old 01-20-2011, 09:15 AM
Zword Zword is offline
array select 1 value
question
for cod in wall_1.getPosition()
	print cod
This will print the x y z coordinates. Now all i want is the z coordinate value. How?
Old 01-20-2011, 09:33 AM
Darkmax Darkmax is offline
	print cod[2]
Old 01-20-2011, 09:41 AM
tried that doesn't work
File "Test wall.py", line 106
SyntaxError: invalid syntax
Old 01-20-2011, 10:38 AM
The point is that my z coordinate is constantly reset to 0.5 but what i want is that it get the object.getPosition += 0.5
def moveWallBackward ():
    global pos
    object = viz.pick()
    if object.valid():
        pos -= 0.5
        object.setPosition([0,-4,pos])
vizact.onkeydown( 'j', moveWallBackward )
Old 01-24-2011, 01:41 PM
vOliver vOliver is offline
cod = wall_1.getPosition()
print cod[2]
Array, concatenate, multiple path help please sircedric4 Vizard 3 10-28-2009 06:14 AM
Semi-circle array containing target and distractor objects ptjt255 Vizard 3 08-04-2009 04:09 AM
2D or 3D array help? durf Vizard 1 02-20-2009 11:57 AM
How can I select and move an object? nlfrnassimi Vizard 1 02-11-2009 02:08 AM
Copy objects in an array to another array Johannes Vizard 3 04-29-2005 03:37 PM
