Old 12-04-2010, 10:47 PM
shahramy shahramy is offline
Red face vizard enterprise edition
Hi.
I have enterprise edition, when I publish EXE file, the published EXE does not read or write to file such as 'a.txt' whereas PY file can do it. please help!
MSc Shahram Shahraki
Old 12-06-2010, 12:22 AM
sleiN13 sleiN13 is offline
It might be a path problem. Do you refer to the .txt file relatively? or with a absolute path. If the first then your text file will be made not next to the exe but in to the directory the exe is unpacked and then executed (somewhere in the c:\windows\temp). You can solve it by doing a absolute path or using viz.getPublishedPath()
Vizard Enterprise Edition and motion capture aaThomas Vizard 4 10-05-2007 10:31 AM
