Old 11-12-2010, 08:58 AM
Make an object transparent if you see it from its back
Is there any simple and easy way of doing this? Disable/hide an object if you see it from its back??
Old 11-12-2010, 09:00 AM
Try enabling back face culling:
node.enable(viz.CULL_FACE)
Old 11-12-2010, 09:07 AM
Great, but can I do the same for a "box" instead of "plane"??
and.. would it be possible to render with a certain alpha instead of full transparency?
thank you.
Old 11-18-2010, 02:36 PM
Back face culling works on any model. However, it does not support rendering with transparency.
Making an object to appear after other object done animating jaylocco Vizard 2 07-13-2009 06:17 PM
How to make an object fixed in viewpoint coordinate system? Xianshi Xie Vizard 1 06-22-2009 11:31 AM
