Old 10-21-2010, 08:31 AM
VIZUNN VIZUNN is offline
Polhemus Liberty Latus error
Hi
I launch a marker with the PiMgr program supplied with the Liberty Latus. The marker is launched successfully and tracks accurately when run with PiMgr. When I run Vizard with the following code, while the PiMgr is still open, I get some errors.
code:
pol = None
pol = viz.add('polhemus.dle')
if not pol.valid():
viz.message('Failed to initialize Liberty Latus')
sensor1 = pol.addLibertyLatus(marker=3, receptor=3)
viz.link(sensor1,bone1,mask=viz.LINK_ORI)
errors:
** ERROR: Failed to connect to a Patriot Wireless/Libert LATUS: Device not found
** ERROR: Failed to create extension sensor with polhemus.dle
** ERROR: Link failed (source linkable is invalid)
If I close PiMgr and run the same code, the system hangs and says:
winviz.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
The marker number is correct and I have tried the addLibertyLatus() method without parameters and I have also re-installed the Polhemus drivers and software without luck.
Any help will be much appreciated.
Old 10-22-2010, 11:21 AM
Please contact support@worldviz.com for further assistance.
Old 02-07-2013, 08:13 AM
Yang Yang is offline
How did you solve the problem?
Hi Vizunn,
I am having exactly the same problem as you do. The only difference is that I am now using Vizard 4.0.
Would you mind giving me some advise in solving the problem?
Thank you in advance!
ERROR: Failed to load .ive file turgutm Vizard 1 09-16-2010 06:16 AM
5DT glove ultra error 5dt.dls failed kabk Vizard 2 05-05-2009 01:43 PM
Loading morph mesh error. vEsotu Vizard 2 03-14-2009 07:29 PM
Polhemus woes Enlil Vizard 2 09-02-2008 10:09 AM
The error window that couldn't FlyingWren Vizard 2 12-02-2003 09:23 AM
