Old 10-10-2010, 05:56 PM
vOliver vOliver is offline
Graphics optimization
I'm trying to optimize a scene so that we can get even framerates on the HMD. I was wondering what options are available in vizard. If this was OpenGL I would turn on backface culling, use display lists for all my models etc. Are those options turned on be default? Any help would be appreciated.
I think my shaders might also be slowing things down considerably even though they are just diffuse shaders. I tried turning my shaders off and a lot of textures seem to be rendering to completely black now when viewed at the wrong angle. Is that a common problem? IE with my simple shader using
fragColor = texture2D(tex, texCoord.st)
i get fine looking textures and with vizard default some show up completely black. Maybe this has something to do with lighting settings?
Thanks for any help
Old 10-18-2010, 04:40 PM
Backface culling should be turned on by default. If it has been disabled you can enable using <node3D>.enable(viz.CULL_FACE).
If you are using 3ds Max one way you can optimize the scene is by using OSG occluder nodes.
You might also try the <node3D>.optimize command to see if that helps.
more than 1G Graphics Memory martinb Vizard 1 10-23-2009 10:48 AM
Graphics accelerator problem JRichizzle Vizard 4 10-14-2009 06:48 AM
Question on Graphics Card for laptop Vinicius Lima Vizard 1 11-12-2008 03:59 PM
Quadro Graphics Card Problem Vinicius Lima Vizard 4 04-08-2008 10:54 AM
Recommended graphics card? Vince Vizard 4 07-13-2005 10:10 PM
