Old 10-08-2010, 12:58 PM
Question Mouse zoom
I am using camera = vizcam.PivotNavigate(center=[0, 2, 2], distance=2.5)
The mouse wheel reduces the zoom factor exponentially as I zoom into some object. How do I make it stop or change this behavior?
Old 10-08-2010, 01:18 PM
Create your own class that inherits from PivotNavigate and override the mouse wheel behavior:
class MyPivotNavigate(vizcam.PivotNavigate):
	def _camMouseWheel(self,e):
		# Compute new distance base on mouse wheel
		dist = self.getDistance() - e.dir
		# Make sure distance does not drop below zero
		dist = max(dist,0.01)
		# Apply new distance
		self.setDistance(dist)
cam = MyPivotNavigate()
Old 05-04-2012, 08:06 AM
kovitch kovitch is offline
Is there a way to override mouse wheel in the Panorama Camera class?
All I want is a Panorama Camera with the zoom in and zoom out capabilities.
Best regards,
Alex.
Old 05-04-2012, 10:02 AM
Solved. Changing the Field of View is enough for my purposes.
For those who care:
def onMouseWheel(dir):
	if dir == 1:
		viz.fov(40,1.3333)
		viz.fov(70,1.3333)
viz.callback(viz.MOUSEWHEEL_EVENT,onMouseWheel)
Warning mouse() -> Set mouse() of window johannes2 Vizard 1 08-19-2010 02:11 PM
how to remove velocity when mouse is disabled? jvacare1 Vizard 2 02-18-2010 10:25 AM
Navigating an avatar using mouse position(2D) in 3D environment james007 Vizard 1 10-16-2009 11:29 AM
Mouse problem steve Vizard 7 07-14-2005 03:01 PM
Draw Line between Points selected by mouse Johannes Vizard 7 01-07-2005 02:50 PM
