Old 09-21-2010, 07:59 PM
Question pick() & "GEODE" problem
I created a plane on 3DS, applied a texture and exported it to .IVE
Now I am trying to get the NAME of this object (wall01) through pick(). However I get either "Material #39" on objects with texture or "Wall01-GEODE" for objects without texture. How do I get "wall01" for an object with texture? And how can I make the export not generate these -GEODE things?
object = viz.pick(1, viz.WORLD)
print object.name
I tried pretty much everything I could find on the forum, and I still have no clue as to how get "wall01" as a return to pick(). Any ideas???
Old 09-22-2010, 07:11 AM
After switching to .3DS, the problem is gone. Is this a problem or limitation with the .IVE file format?
Old 09-23-2010, 11:19 AM
The object.name field will hold the name of the lowest level transform. In the case of the .ive file that is a texture unless there is no texture. What you can do is get a handle to the child object using <node3D>.getChild and then check to see if that was picked:
gallery = viz.addChild('gallery.ive')
painting = gallery.getChild('art04-FACES')
def showPicked():
	object = viz.pick()
	if object == painting:
		viz.logNotice('Dali painting picked')
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,showPicked)
The following article shows what you can do when you get a handle to the GEODE sub-object in your script:
http://kb.worldviz.com/articles/1157
winviz.exe problem llqqff Vizard 2 07-16-2010 09:08 AM
Pick porblem with arrays shivanangel Vizard 3 08-27-2007 10:10 AM
picking problem... k_iwan Vizard 2 07-27-2007 07:57 PM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
