Old 09-08-2010, 07:37 AM
Chapre Chapre is offline
How to add animation to a still model
Hello, I'm new in vizard, I have a wheelchair model that I can move easily in the 3d world, the only problem is that the wheels don't spin. I'm using 3D studio max 2011, could someone give me a quick tutorial on how to add that spinning animation to the wheelchair model, please!
Old 09-08-2010, 12:22 PM
If the wheels are sub-parts of the wheelchair then you can get a handle to and spin them in Vizard. The following article describes how to get handles to sub-objects and rotate them around their local origin:
http://kb.worldviz.com/articles/1157
Old 09-09-2010, 05:21 PM
Thanks Jeff for this tutorial!
I noticed that the format used was ".IVE" as it got "GEODE" node included.
- How would we spin the wheel if the file format was ".3DS"?
- Can we include that spinning animation in the same file (wheelchair.IVE) and then when we load the file in vizard, to spin the wheel we just write:
>>>wheel= viz.add('wheelchair.IVE')
>>>wheel.state(x)
Old 09-09-2010, 06:04 PM
The extension .ive is the compiled form of the OSG format. We have an OSG exporter for Max available on our downloads page.
The easiest way to control the animation of spinning wheels would be to use the method described in the tutorial above.
Otherwise, you could create the animation in Max and export to OSG format. To play/stop it in Vizard you would need to use the module provided in the following thread:
http://forum.worldviz.com/showthread.php?t=2709
Old 09-09-2010, 06:15 PM
Very helpfull
After a using speak, model returns to idle animation? Enlil Vizard 4 08-06-2010 12:42 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 02:11 PM
