Old 08-25-2010, 12:51 PM
Enlil Enlil is offline
Collide mesh on child objects
I have found that if I grab a child object and create a collide mesh from it, no mesh is actually created, or at least my other physics objects do not register collisions with it.
The specific issue is grabbing a door object and rotating it to simulate opening. If I make a collide mesh from an object rooted in the world, the collide mesh works but does not update when I rotate the world. If I create the mesh from the child, no collision occurs.
What am I doing wrong? Or is there a better way to do this?
Christian
Old 08-31-2010, 05:52 PM
Collide shapes will be positioned correctly when they are associated with objects that are children of the world. Can you post an example that replicates your problem when the object is a child of the world?
detect collision with child objects Jerry Vizard 1 12-09-2009 01:40 PM
Registering 2 objects to show the collide djones1010 Vizard 1 03-25-2009 12:35 PM
Pivot points for child objects in Vizard with 3ds Max Gladsomebeast Vizard 0 09-19-2006 11:21 AM
3D sound & child objects FlyingWren Vizard 1 09-19-2003 12:13 PM
max child objects hotspur1 Vizard 2 06-19-2003 06:55 AM
