Old 07-09-2010, 06:39 AM
nachac nachac is offline
Post Marker moves in x-direction
Hi everybody,
I've got following problem:
I've got a marker and want to cause an action when this marker was moved into x-direction.
So how can I measure this marker was moved for e.g. 0.3 in x direction?
y- and z- direction are unimportant in this case. Is there any function?
Thanks for your help!
Old 07-12-2010, 05:41 PM
You could get check the position of the marker in Vizard every frame and if the x value is greater than 0.3 you could start the action.
def checkPosition():
	if tracker.getPosition()[0] > 0.3:
		#add some action here
vizact.ontimer(0,checkPosition)
Old 07-26-2010, 05:15 AM
Thanks a lot!
This was exactly the answer I wanted to know ;-)
Be a Marker for Camera Tracking CRI Vizard 2 05-31-2010 02:09 PM
AR Marker masking properties CRI Vizard 0 03-27-2010 12:33 AM
marker id plug-in Vkathrynr Precision Position Tracker (PPT) 1 09-25-2009 04:31 PM
Tracking with Marker ID plugin mjabon Precision Position Tracker (PPT) 9 07-13-2009 12:36 PM
Draw Vector in viewpoint lookat direction Chrissy2009 Vizard 2 05-30-2009 01:50 AM
