Old 07-03-2010, 11:41 AM
moneim230 moneim230 is offline
Question Physics - addThruster
i applied a constant force on an object and i wanted to change its value
F=[0,0,0]
def UpdateThruster():
	force=ball.addThruster(mode=viz.ABS_GLOBAL,force=F)
vizact.ontimer(0,UpdateThruster)
def onKeyDown(key):
	if key == ' ':
		F[2]=1
i found that the force is accumulated each time the function UpdateThruster happens
so, when i press space once, the ball starts accelerating very fast
please i need to apply a force and change its value anytime i want...how can i do this ??
Old 07-05-2010, 02:58 PM
You can zero out any forces already added with the <node3D>.reset method.
Old 07-11-2010, 12:03 AM
Lightbulb
thanks Jeff
i have a question here
is there a better way than this (calling a function with 0 timer) to update the value of the force
actually i am working on a vehicle model and i need to get the inertia force applied when i leave the gas pedal
help with augmented reality and physics Darkmax Vizard 1 06-12-2010 03:26 PM
RE:Slide Joints and physics optimization nige777 Vizard 4 06-22-2009 04:21 PM
Physics and Haptics jalvarez Vizard 3 07-16-2008 03:03 PM
collision with physics enabled joeymax Vizard 2 04-17-2008 02:49 PM
another physics question adimov Vizard 1 07-22-2004 03:56 PM
