Old 01-26-2005, 11:24 AM
jkelly jkelly is offline
hierarchicy with on-the-fly objects
I am interested in creating an on-the-fly object , and adding it to a hierarchy with a vrml object as the root. Is there a way to indicate in the viz.endlayer() command that it should be attached to an already-existing object? I tried the following:
myObject = viz.add('object.wrl')
viz.startlayer(viz.LINE_LOOP)
viz.vertex(0,0,0)
viz.vertex(0,1,0)
myLine = viz.endlayer(myObject)
This did not work, however. Can you suggest a better way to do this? Thanks.
Old 01-26-2005, 11:26 AM
What you did should work. Are you using an older version of Vizard? Either way, the following will work also:
myLine = viz.endlayer(myObject.id)
Old 01-26-2005, 11:30 AM
That works great. I am using 2.17a, which is probably the problem.
Thanks.
Jon
