Old 06-28-2010, 02:33 PM
Mike@vrs Mike@vrs is offline
Tutorial Example - inverted video
Hi
I am following through the example "Getting Your Feet Wet"
and notice that on the screen the video I have selected
is inverted and appears to be a mirror image of what it should be.
#Play a movie on the screen
def playMovie():
mymovie = viz.add('rockpool2.wmv')
mymovie.loop(viz.ON)
mymovie.play()
screen.texture(mymovie)
vizact.onkeydown('m', playMovie)
[question] Can this be adjusted to play correctly.
Old 06-29-2010, 03:42 PM
It looks like the texture coordinates on the model are inverted. You can reverse them by using the node.texmat command and setting the wrap mode of the texture to REPEAT:
def playMovie():
	mymovie = viz.add('rockpool2.wmv',wrap=viz.REPEAT)
	mymovie.play()
	screen.texmat(viz.Matrix.scale(-1,1,1))
Old 06-30-2010, 10:49 AM
Inverted video
This solution appears to play the video, however the sound only is heard, the picture is a black screen?
Old 06-30-2010, 11:26 AM
Inverted video
Hi
I was able to invert the video in windows movie maker (using effects) and the video was then inverted in vizard thus playing correctly. However getting a scripting solution would be good so any advice would be great.
Mike
synching video camera recording with vizard billjarrold Vizard 0 12-16-2009 12:43 AM
Adding Multimedia --inverted image adele Vizard 1 06-23-2009 01:00 PM
video help nasr Vizard 2 05-26-2009 12:42 PM
lat long mapped video Brett Lindberg Vizard 3 02-25-2009 08:41 PM
How to synchronize play/pause of 2 video streams in stereo Gilliard Vizard 1 09-01-2005 09:58 AM
