Old 06-28-2010, 09:50 AM
llqqff llqqff is offline
About using Vicon Tracker with world viz
Vicon released a new software called Vicon Tracker and the brochure says it can be used lively with vizard in world viz, is there any instructions or codes that can show me how to do the connection between Tracker and Vizard or how to transfer the real time data from Tracker to Vizard? Thanks.
Old 06-28-2010, 10:28 AM
Their website claims that it uses the VRPN protocol, so you should be able to use the vrpn plugin that comes with Vizard. You will need to consult with them to find out which version of VRPN it uses and and the name of the tracker to connect to.
why is time faster in my virtual world? billjarrold Vizard 1 11-24-2009 06:33 PM
vicon pluglin - cluster problems Andy Vizard 2 11-10-2009 02:04 AM
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 01:03 AM
Simple Head Tracker PHart Vizard 1 05-10-2009 06:35 PM
General Questions about Vizard: World Viz dav Vizard 5 08-28-2006 04:44 PM
