Old 04-29-2010, 06:16 PM
Multiple Geodes?
Hello again Vizard Gurus.
I had a small question on pivot points coming out of 3D Studio Max.
I am aware, thanks to your tutorial, of setting up a geode in max to
create a single pivot point for an object.
But in my case, I have an object that requires more than one 'pivot' point.
Meaning, I am currently using the geode location as a point of reference
for drawing curves from one node to another.
Is it possible to have more than one? Or is it possible to add more points? Or perhaps there is a better work around that I am missing.
I know I could have multiple pieces of geometry with Geodes, but is it possible
to make an 'empty' set for additional geodes?
For instance, if I need to 'lock' items to different points on a model, is there
a better method than this?
Thanks for your time,
George L.
Old 05-04-2010, 10:43 AM
Typically when we want to add in extra points to move or attach other things to, we add some boxes in max, move them so their pivot is in the desired location, and assign a fully transparent material to make them invisible.
Old 05-06-2010, 07:01 PM
Thanks Veleno,
I was hoping there would be a slightly more elegant solution, but
if it works, I'll take it!
~George
trouble tracking multiple lights Vkathrynr Precision Position Tracker (PPT) 2 08-26-2009 12:07 PM
output to multiple (two) sound devices GiudiceLab Vizard 1 08-05-2009 01:12 PM
removing multiple objects durf Vizard 7 08-05-2009 09:15 AM
multiple views durf Vizard 3 05-07-2009 11:26 AM
creating multiple coordinate systems and making them visible jalvarez Vizard 1 02-27-2009 12:36 PM
