Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 04-13-2010, 07:20 AM
jde jde is offline
3ds MAX to Vizard - Render to Texture Problem
I was wondering if anyone has experience burning lighting and shadows in 3DS Max. I followed the Vizard tutorial on texture burning (available on the vizard support site) but I get strange artifacts in the shadows. My radiosity solution also looks strange (using an IES Sun casting shadows on a 3D maze -- see pictures at link below).
Has anyone experienced this problem? What techniques do you use to generate realistic lighting for your Vizard displays? Are there any key parameters I should be messing with to get a more realistic solution and avoid the artifacts?
Pictures available here: http://area.autodesk.com/forum/autod.../sun-+-shadows
Jon
3D Texture Mapping in Vizard? stefs Vizard 2 03-25-2008 03:34 AM
Skydome texture problem theuberk Vizard 2 01-18-2008 05:56 AM
newbie problem getting vizard to work Colin Vizard 2 11-10-2006 10:54 AM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 10:52 AM
