Old 03-18-2010, 06:46 PM
Textures of wrl file
Hi All
I'm currently working on a simple program that loads up multiple wrl files which are made by the user.
The problem is that sometimes they dont have the textures in the correct place.
Is there a way to check to see it the textures have loaded correctly on a model? i want to put an error on my loading screen if they have not.
i was going to do it by using <node3d>.getTexture but i cant seem to get anything to work.
Old 03-19-2010, 03:05 PM
i suppose i could search through the wrl file and find the textures location then see if the image exists.
Old 03-22-2010, 11:26 AM
What are you using to create and export the models?
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 02:20 AM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 11:44 AM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 03:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 10:44 AM
Textures not showing drahcir Vizard 1 08-15-2005 11:43 AM
