Old 02-16-2010, 11:03 AM
just alex just alex is offline
Outputting modules
I have a sneaking suspicion that this is really easy, but I'm just not seeing how to do this. I've got a module that's supposed to take the data from my tracker and figure out what my subject is looking at. I'm trying to make this data get written into a data file when my subject collides with an object in the main program. I think the code should look something like
import math
import vizmat
import vizinfo
from lookingat import LookingAt #the module
#adds the ppt
PORT_PPT = 1
ppt = viz.add('vizppt.dls')
ppt.command(3,"",1,1,5)
PORT_INTERSENSE = 2
isense = viz.add('intersense.dls')
tracker = viz.add('intersense.dls')
viz.tracker()
tracker.reset()
# open a datafile for recording
subject = viz.input('Subject number:')
filename = 'subject' + str(subject) + '.txt'
datafile = open(filename,'a')
#testing collisions
viz.collision(viz.ON)
view.rotate(0,1,0,90)
def mycollision(info):
   datafile.write('collision','a')
   datafile.write(str(Lookingat),'a')
   datafile.flush()
viz.callback(viz.COLLISION_EVENT, mycollision)
with the lookingat file like this
## IMPORT LIBRARIES ##
from math import cos, sin, radians
import vizmat	# library for vector math
## RUNTIME MODULE ##
class LookingAt:
	# Constructs a new LookingAt object, which contains a pointer to
	# the client's viz.
	# @param vz: current Vizard instance (just pass in viz)
	def __init__(self, vz):
		self.v = vz
	# Calculates a projected point from given viewpoint at the given proximity.
	# @param pos: position of view
	# @param euler: euler coordinates of view orientation
	# @param proximity: distance of projected point from viewpoint
	# @return: Projected point
	def projection(self, pos, euler, proximity):
		theta = radians(euler[0])
		phi = radians(euler[1] + 90)
		xProj = pos[0] + proximity*sin(theta)*sin(phi)
		yProj = pos[1] - proximity*cos(phi)
		zProj = pos[2] + proximity*cos(theta)*sin(phi)
		return [xProj, yProj, zProj]
	# Finds the point ([X, Y, Z]) on the object the user is looking at.
	# @param v: viz pointer
	# @param proximity: max distance of viewed objects from viewpoint
	# @param objects: OPTIONAL list of objects to restrict intersection to
	# @return: Point on object, or None if not looking at any objects
	def lookingPoint(self, proximity, objects=0):
		pos = self.v.get(viz.HEAD_POS)
		euler = self.v.get(viz.HEAD_EULER)
		proj = self.projection(pos, euler, proximity)
		intersection = self.v.intersect(pos, proj)
		if intersection.valid:
			if (objects == 0):
				return intersection.point
			for object in objects:
				if (intersection.object == object):
	# Finds the closest object the viewer is directly looking at.
	# @return: Object looking at, or None if not looking at any objects
	def lookingObject(self, proximity):
			return intersection.object
however, i'm not getting this to work correctly. Am I missing a step in properly importing the lookingat data, or is there an error in the code I'm using to output the collision data?
importing modules from Psychopy starbug Vizard 0 02-08-2010 08:06 AM
Modules / Require / Include function Johannes Vizard 4 04-27-2005 11:12 AM
