Old 02-08-2010, 08:40 PM
jassel41 jassel41 is offline
Converting a character to a number
I am currently trying to figure out how to retrieve a character from a text file and turn it to a number.
I currently split up the sentence and store the word I am interested in into an array, for example a spot in the array may look like the following:
['Interval=4;']
What I want to do is access the 4 and save its numeric value to a variable. If this is stored in array[1] for example, is there a way to access the 10th character, (the 4) and then convert it to a number?
Thank you,
Jassel41
Old 02-10-2010, 07:37 AM
JvdBosch JvdBosch is offline
string = 'Interval=4'
string.split('=')[1] will return 4 (as string)
int(string.split('=')[1]) will return 4 (as int)
string[9] will return 4 (as string)
int(string[9]) will return 4 (as int)
And so on. Good luck!
Special character adimov Vizard 1 06-15-2009 12:32 PM
character pack and walkto ? digitaldarklord Vizard 1 09-30-2008 04:42 PM
Native WorldViz support for character animation luakt Vizard 10 09-15-2008 11:39 PM
Locking every bone of a character Frank Verberne Vizard 2 03-17-2008 10:21 AM
limits on number of objects benelux Vizard 3 07-22-2004 01:26 PM
