Old 02-08-2010, 06:00 PM
ursi ursi is offline
scheduled animation paths: jumps
Hi
Three animation paths should be scheduled one after another.
The path speed should be 100 steps/sec
pathFW.speed(100) # default: 1/sec?
I thought the waiting time should be devided by 100 as well>
yield viztask.waitTime(len(BW_Pos)/100)
My schedule looks like that, but in the animation there is a jump at the end of the first animation path... I guess, there is a timing problem and the system starts with the second path (pathStopp) before the 1st path (pathFW) is finished.
def onkeydown(key):
	PATH()
	if key == 't':
		### SCHEDULE the room movement, sound and the output voltage
		def ScheduleOutputs():
				song.play()
				d.eAnalogOut(3.0, 0.0) #(AO0, AO1)
				pathFW.play()
				yield viztask.waitTime(((len(FW_Pos))/100))
				d.eAnalogOut(1.0, 0.0)
				pathStopp.play()
				yield viztask.waitTime(((len(Stopp_Pos))/100))
				pathBW.play()
				yield viztask.waitTime(((len(BW_Pos))/100))
				song.stop()
		viztask.schedule(ScheduleOutputs())
So, how can I manage that timing problem?
File Type: txt SledMotionStopp.txt (886 Bytes, 4405 views)
Old 03-11-2010, 03:51 PM
bloswald bloswald is offline
viztask.schedule only once?
I think I have a similar problem. Maybe I just don't understand viztask very well, but it seems that you are unable to schedule a function more than once. Can I have someone with authority agree or disagree with this? Here is some code demonstrating what I am talking about.
def print_this():
	print "this"
	yield viztask.waitTime( 0.1 )
vizact.onkeydown( 'p', viztask.schedule, print_this() )
If I wanted to call print_this() multiple times, how would I go about doing that?
In my application I am assembling/disassembling a model (also with animation paths). When I typed vizact.onkeydown( viz.KEY_DOWN, disassemble_all ), my program would only call the function the first time I pressed the key. I want the parts to disassemble one at a time rather than all at once.
bloswald
Last edited by bloswald; 03-11-2010 at 04:00 PM. Reason: Adding signature and smiley :)
Old 03-11-2010, 04:03 PM
Oops. I meant to say: vizact.onkeydown( viz.KEY_DOWN, viztask.schedule, disassemble_all() )
bloswald
Old 04-27-2010, 01:12 PM
Talking Solved
Since my last post, I have learned that tasks require a different way of thinking.
The following code worked for my purposes, and viztask.schedule is only called once.
def print_this():
    while True:
        yield viztask.waitKeyDown( 'p' )
        print "this"
        yield viztask.waitTime( 1 )
viztask.schedule( print_this() )
Sometimes you have to forget about the problem for a while, then the solution shows itself.
bloswald
Old 06-17-2010, 12:17 PM
Smile Better solution
Here is an even better solution.
import viztask
def print_this():
	print "this"
def intermediate_function():
	viztask.schedule(print_this())
vizact.onkeydown( 'p', intermediate_function )
bloswald
speed on animation path whj Vizard 8 11-17-2008 08:41 PM
Animation Tracks.... k_iwan Vizard 2 03-26-2007 06:52 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 03:11 PM
animation sequence pkhoosh Vizard 2 01-23-2006 09:03 AM
avatar animation problems jrodman Vizard 1 01-18-2006 10:12 AM
