Old 02-07-2010, 03:14 AM
omidbrb omidbrb is offline
About getAlpha function
I have a problem using the getAlpha function. I'm calling getAlpha on the resulting object from the pick function:
intersect = win.pick(True, viz.WORLD, pos = [xNorm, yNorm])
alpha = intersect.object.getAlpha()
But whatever node I pick (even if transparent), getAlpha results 1, which means completely opaque.
Does anybody have an idea on that?
Omid
Old 02-08-2010, 12:37 PM
Does the object have multiple sub-nodes with different material settings? If so, then this might be why you are not getting the correct alpha value.
return variable from keypress function starbug Vizard 2 01-07-2010 11:14 AM
window.pick function over sub-window omidbrb Vizard 4 10-02-2009 04:23 AM
Documentating function names aaThomas Vizard 5 05-15-2007 09:50 AM
Do you know how to send a value for 'pool' to the onActionEnd function? ghazanfar Vizard 1 03-22-2007 10:25 AM
timers and director function Jerry Vizard 1 06-22-2006 09:47 AM
