Old 02-02-2010, 07:37 AM
ohad ohad is offline
Question BioPac - acquisition problems
I'm using BIOPAC's MP150 system to acquire some physiological data.
To do this I'm using some methods from "acqserver.py ".
On one of the acquisitions (That includes 6 channels - 2 analog and 4 calculated) I'm reading one of the clculated channel using this command :
bpm = myAcqServer.getMostRecentSampleValue("calc",0).
It works just fine.
When trying to apply the same method to another acquisition (2 analog channels solely), changing the channel type and ID to this method :
bpm = myAcqServer.getMostRecentSampleValue("analog",13)
I'm getting an exception :
" raise ACQServerException(str(exobject))
acqserver.ACQServerException: <Fault 0: 'Unable to get most recent value for channel'>".
In both tries the acquisitions itself (on another computer LAN connected) runs smoothly.
Any idea how should I start troubleshooting?
Ohad
Old 02-03-2010, 01:14 AM
Forgot to mention (as this should be the first thing to check) -
before using :
I remembered to enable the channel with : "myAcqServer.changeMostRecentSampleValueDeliveryEn abled("analog",13,True)
Any other idea?
Thanks again,
Ohad
Problems loading WRL file DrunkenBrit Vizard 2 01-29-2009 12:58 AM
2 problems with our HMD Vbents Precision Position Tracker (PPT) 1 07-26-2006 07:55 PM
Export/import problems and Vizard 3.0 release searsky Vizard 0 01-03-2006 01:34 AM
Problems with lighting in 2.0 murm Vizard 6 04-21-2004 09:59 AM
