Old 11-28-2009, 11:07 PM
Performance Factors for On-The-Fly-Objects
Hi Vizard Online Support Team,
I had a question regarding the performance penalties associated with "on-the-fly" objects. Specifically, how to increase performance for a terrain asset.
I have been reviewing terrain generating algorithms (specifically for DirectX)
and one key area that is continually pounded upon is the number of polys being
sent to the pushed out at a time. In these examples they slice up a large
terrain generated by a displacement map into smaller objects for optimization
reasons.
I am wanting to bring this algorithm into Vizard to generate my own terrain and
was wondering if you could give any heads up on the best course I should
take with an on-the-fly object.
Should I just cram all the polys into one object and let Vizard handle it,
splice them up and see if I gain any performance value, or some other
solution that you gurus at Vizard probably are aware of that I am not.
Also, another question that I've had is the use of index buffers and vertex
buffers inside of Vizard. For something like this, the benefits are noticeable
and I was wondering if Vizard had any support for this natively.
Thank You,
George L.
Rowan University VR Lab
fps performance caused by garbage collection? Mike Konstant Vizard 7 09-03-2012 01:44 PM
Semi-circle array containing target and distractor objects ptjt255 Vizard 3 08-04-2009 04:09 AM
Invisible haptic objects Haptiken Vizard 1 05-05-2009 05:04 PM
Improve performance with large number of onthefly objects? Fox5 Vizard 7 04-28-2008 06:19 PM
