Old 11-24-2009, 01:12 PM
llqqff llqqff is offline
Forearm not rotating in live characters
Hi, I am doing some research on live characters. Now I have a problem on the forearm not rotating. I use the motion capture(blade) to get the real time data and stream the data into motionbuilder. The skeleton from motion capture is good and moving with subject, and other bones is right. Only the forearm is not
rotating with the real-time human motion.
Does anyone know what's the problem and how to fix it? Thanks.
Qiufeng
Old 12-09-2009, 01:21 PM
If the forearm of the actor in Motionbuilder is not moving properly you might need to do another t-pose and better adjust the actor to that data.
Or is it the case that the actor's arm moves correctly and that when you re-target this data to a Vizard character that the character's arm does not follow properly?
Live Characters plugin Frank Verberne Vizard 7 03-01-2012 03:23 AM
How to disconnect the live characters? llqqff Vizard 1 11-03-2009 10:02 AM
Trouble using custom animations for Live Characters IGoudt Vizard 0 09-24-2009 07:37 AM
Linking problems with Live Character Frank Verberne Vizard 5 06-04-2008 12:42 PM
Live Characters Demo wouters Vizard 3 05-06-2008 10:14 AM
