Old 10-20-2009, 01:28 PM
Enlil Enlil is offline
Network format
Hello, I am writing a C# application that communicates with a vizard program, and looking at the message sent from the vizard program, the format looks pretty complex! I am not too worried about parsing the vizard message in C#, but am not so sure about writing the code to send a UDP packet from C# to Vizard that the vizard networking accepts.
So, I was wondering, is there any documentation on the format?
Thank,
Christian
Old 10-21-2009, 09:30 AM
I looked into it further, and it turns out the message format is pickled - that is why it looks so odd. So I am working with IronPython to try to reverse the process and get at the data.
Christian
Old 10-23-2009, 10:29 AM
The data that is transmitted by Vizard is pickled using the cPickle module. To get access to the data on your end you can use the following code:
data = cPickle.loads(rawData)
The variable data should be a tuple containing:
  1. The senders computer name
  2. A tuple containing the positional data from the <network>.send() command
  3. A dictionary containing keyword data from the <network>.send() command
Using 5DT plug-in with the data coming through network... mcicek Vizard 1 05-18-2009 05:17 PM
continually losing network license ad_astra Vizard 1 11-30-2007 02:48 PM
Best image format Pastscapian Vizard 2 10-09-2006 10:44 AM
White Fullscreen crash when running network version Dbuckland Vizard 6 04-19-2006 02:49 PM
more advanced network examples? halley Vizard 0 04-05-2006 07:07 AM
