Old 09-16-2009, 06:54 PM
atamasan atamasan is offline
Question I have a question about link data
Hi.
Now I finally solve my problem(I posted before).
But only one thing make me confused.
When I use link, source data is different from destination data.
Uh, for example....
sensor=viz.addSensor('patriot')
hand=viz.add('hand.cfg')
bone=hand.getBone('bone index 1-2')
bone.lock()
link=viz.link(sensor,bone)
def print(e):
    print sensor.getEuler(), bone.getEuler()
viz.callback(viz.UPDATE_EVENT,print)
bone is linked, so I think "sensor.getEuler() and bone.getEuler() are same data, but it's different.
Do you have any idea for this?
Thank you very much.
Old 09-17-2009, 05:47 PM
Link objects do not get updated until later on in the update cycle. There are a few ways to deal with this.
1) Register your callback with a priority greater than viz.PRIORITY_LINKS
2) Manually update the link before retrieving the values from the bone:
link.update()
3) Retrieve the euler values directly from the link:
print link.getEuler()
Old 09-17-2009, 06:47 PM
Hi, farshizzo.
Thank you for your advice.
I didn't know "viz.PRIORITY_LINKS".
I'll try the manually update method you taught me.
Thank you again.
Using 5DT plug-in with the data coming through network... mcicek Vizard 1 05-18-2009 05:17 PM
Flagging the Data Elittdogg Vizard 5 04-11-2008 11:40 AM
Flock of Birds question (again) Elittdogg Vizard 24 12-04-2007 09:37 AM
5DT Data Glove 5 Ultra Flexure Question bjgold Vizard 1 07-25-2006 02:58 PM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 08:48 AM
