Old 08-25-2009, 11:38 AM
vissimutah vissimutah is offline
Distance or position based event?
We're trying to play a sound when the viewpoint reaches a certain point in the virtual environment. Do we have to register a custom event to do this? Is there a way to use a loop without freezing the program?
Old 08-25-2009, 12:26 PM
It seems like you simply want to run some code every frame. In that case you can register a timer function, which will be called every frame. Here is an example that plays a sound when the Z position of the view passes 3 meters:
viz.add('tut_ground.wrl')
def CheckView():
	"""Plays a sound when Z position of view is greater than 3"""
	x,y,z = viz.MainView.getPosition()
	if z > 3:
		# Play sound and unregister timer function
		viz.playsound('elaugh1.wav')
		return vizact.EventRemove
vizact.ontimer(0,CheckView)
default start position erchrastil Vizard 2 06-23-2008 08:15 AM
position of html-file on screen active_world Vizard 1 05-16-2008 07:24 PM
Avatar always returns in initial position pattie Vizard 2 08-31-2006 08:15 PM
Get position data in an own little program Researcher Precision Position Tracker (PPT) 2 02-01-2006 02:55 AM
