Old 08-03-2009, 06:01 AM
atamasan atamasan is offline
Smile Problems Between Vizard and Polhemus
Hello.
I am a student and am studying 3DCG(hand move).
Now, I use 16 sensors(Patriot, 15 sensors for finger bones and 1 sensor for bone Root) for my right hand.
The hand model and my right hand(with sensors) do the same movement, this is my purpose. Maybe it is not so difficult.
So I made code to do that.
In my code, patriot's datas are calculated by my own methods(for initialization,for rotation matrix, for inverse matrix etc...) But it's hard to achieve my purpose(which is mentioned above) with my own method because my code is so long that runs slowy.
So I think there are some useful "vizard commands" for my purpose, but all things are explained in English. Sadly, I'm not good at reading English. Of course I understand this is my responsibility.
Please show me some useful commands or examples if you know.
I really need your help.
Thank you for reading my message.
Old 08-03-2009, 06:08 PM
Are manually performing the matrix operations in your Python code? If so, Vizard already comes with a matrix class that you can perform many operations on (multiplication, inversion, etc..). Open the documentation and look under Command Index -> Vizard objects -> transform for a list of operations available on transform objects.
Old 08-04-2009, 08:22 PM
Thank you very much.
Yes. So I need some useful commands.
I'll try the commands you told me.
Thank you again.
Polhemus woes Enlil Vizard 2 09-02-2008 10:09 AM
Vizard R3 beta release tobin Announcements 4 10-30-2006 11:05 AM
Vizard and Polhemus Patriot bjgold Vizard 8 09-18-2006 03:05 PM
Polhemus Patriot Tracking System: Support/Problem FrankPSchulte Vizard 3 08-10-2006 05:50 PM
Support Polhemus Insidetrack and Cybermind Visette Pro HMD mspusch Vizard 1 03-08-2003 12:14 PM
