Old 07-27-2009, 09:15 AM
whj whj is offline
3D sound in Vizard
Could anyone tell me whether spatialized audio in Vizard involves y-axis information and orientation information?
For the y-axis information, when there are two sound source just in different height, can listeners tell the difference? (I assume different x or z positions makes difference.)
For the orientation information, when the sound source is static and the listener turn around without changing his position, can he tell the difference?
Thanks a lot!
Old 07-28-2009, 12:31 PM
Yes, the sound which is higher along the Y-axis will have a lower volume. The further away the sound is from the user, the quieter the sound will be.
Old 07-28-2009, 12:42 PM
whj whj is offline
Thank you for the reply.
Does Vizard3.0 support directional sounds? Or even doppler effects?
3D sound in vizard virtmeg Vizard 1 01-10-2005 09:06 AM
