Old 07-23-2009, 02:12 AM
jaylocco jaylocco is offline
Vizact.call error
hi,
I got this problem..I kept on getting error with this code
action = vizact.sequence(vizact.call(Pushed.visible,True),vizact.call(PushedWalkBtn))
vizact.onpick( PushBox, Pushed.runAction, action)
def PushedWalkBtn():
	stopcollide()
	carPAUSEaction()
	inviscar()
and the result says
action = vizact.sequence(vizact.call(Pushed.visible,True),v izact.call(PushedWalkBtn()))
NameError: name 'PushedWalkBtn' is not defined
to what I saw in Vizard help, the syntax should be no problem which is
<vizact>.call(
func
args
May I know what was the problem?
THANKs
Old 07-23-2009, 09:49 AM
You are referencing the PushedWalkBtn function before you define it. That is why the error says PushedWalkBtn is not defined.
Just place the function definition above the action definition and it should work:
	stopcollide()
	carPAUSEaction()
	inviscar()
Old 07-23-2009, 06:51 PM
hah...silly me...thanks for correcting..
5DT glove ultra error 5dt.dls failed kabk Vizard 2 05-05-2009 12:43 PM
Loading morph mesh error. vEsotu Vizard 2 03-14-2009 06:29 PM
Strange Wii Mote error... shivanangel Vizard 8 02-18-2009 12:32 PM
Error Message Jerhy Vizard 1 02-28-2006 01:59 PM
The error window that couldn't FlyingWren Vizard 2 12-02-2003 08:23 AM
